Enables the Layer 2 VPN MAC address withdrawal capability.
| l2vpn | Designates L2 VPN configuration. |
| vpls | Designates VPLS of MPLS configuration. |
| peer | Designates VPLS peer. |
| ipaddress | Selects the VPLS peer of the provided IP address. |
| all | Selects all VPLS peers. |
| fdb | Designates FDB. |
| send-mac-withdrawal | Enables sending the MAC address withdrawal message. |
Enabled.
Use this command to enable FDB MAC withdrawal after it has been disabled.
The following command enables MAC address withdrawal message for all VPLS peers:
# enable l2vpn vpls peer all fdb send-mac-withdrawal
The l2vpn keyword was added in ExtremeXOS 12.4.
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.1.1 Licensing Guide document.
